XCF16P Simulation Model
I'm trying to create a FPGA Design which is able to Program an XCF16P Prom via JTAG Interface (referring to XAPP975). Now I'm asking if there is an Simulation Model for the XCF16P so that I can verify my Design using Modelsim.
To be exact, I'm searching for some VHDL or Verilog Module which can be connected to the JTAG Ports an which is "answering" the JTAG Commands at the TDO Port.
 Hope someone can Help.
Message Edited by bonsaipappel on 03-24-2010 02:44 AM
This does not exist.
Historian
Historian
bonsaipappel wrote:
This should be relatively straightforward to create.
