connecting simulink with fpga board
Hi all!
Currently i am doing power system analysis in simulink matlab. I have developed simple power system network using simulink blockset. I want to send signal (voltage and current) to the fpga board(xilinx virtex 4), therefore i want to ask on how i can make simulink communicate with the board. Through my research, i found a device, P160 analog. but i am not so sure whether i can use this device or am i suppose to use data acquisition card. Can someone who know about this reply.
Thank you =)
Re: connecting simulink with fpga board
   If the issue is how the data has to be transferred to the board, I recommend you to use the JTAG connection.
Prashanth.
I article may help you.
http://www.xilinx.com/publications/xcellonline/xcell_51/xc_pdf/xc_dsp-memec51.pdf
Use hardware co simulation application of system generator. using hardware co simulation application send input data from simulink environment .
http://www.xilinx.com/ise/optional_prod/system_generator.htm
http://china.xilinx.com/products/boards/s3estarter/files/s3esk_sysgen_hw_in_loop.pdf
http://www.xilinx.com/products/boards/ml506/docs/ml506_sysgen_dsp_hw_cosim_creation.pdf
Balkrishan
Thanks and Regards
Balkrishan
i am working with a image processing design in system generator,but to input an image into gateway in block lot of simulink blocks are required which converts the image intensity matrix in 1 d vector ,my question if i want to implement my design in fpga how would i input my image data into fpga .
