xilinx .bit file usage
i am working on xilininx XC4010E -3PQ208C & XC4010E --3BG225C devices,
in xilinx tool select one device programming is done and generating .bit file,this file is used to  run two devices,
.bit file is supported or not,
io pin routing working properly or not,
io pin configuarations mismatch or not,
plz clarify once...
Re: xilinx .bit file usage
Please generate separate bit file for each package device
The same bit stream will work for two devices
Thanks and Regards
Balkrishan
Hi Lavanya,
check the following pinout document link for pq208 and BG225, they donot match, therefore you need to have seperate bit files so that you do not damage the device
http://www.xilinx.com/support/documentation/data_sheets/ds006.pdf
