Anonymous
Not applicable
10.1 isim on Linux not seeing latest changes to vhdl files
I'm running ise 10.1 on a Linux system, coding in vhdl, and this latest project is
for an XC9572XL.  (I use 10.1 because we are still supporting some older Spartan
and 9500 parts.)  On this project, I accidentally selected the implementation file
(xxx.vhd) rather than the testbench (xxx_tb.vhd) and clicked on behavioral simulation.
I got a bunch of red lines, realized I'd started the sim on the wrong file, but from
then on, all I get is a sim of the old files.  Even closing ise are restarting it keeps
simulating the old files.  I created a new project and copied in the vhd and ucf files,
that worked ONE TIME, then back to the same old stuff.  I then deleted the entire
isim directory tree and it sims the latest version of the files.  I'm not absolutely
sure simulating the wrong file caused this, but that's when this problem started.  Is there a
setting somewhere that will make it use the latest vhd files, especially if they
have been modified?  Deleting the isim tree seems awfully brutal.  Shouldn't it
use time stamps to keep track of obsolete files?  (My clock is set properly, and
file times are correct.)
Thanks for any suggestions anyone can offer,
Jon
Re: 10.1 isim on Linux not seeing latest changes to vhdl files
The tool is expected to catch the change in simulation sources.
What if you run "Cleanup Project Files" from Project menu?
