ronagyl_adi
2018.2 SystemVerilog randomization
The below example is taken from LRM 18.3 Concepts and usage.
The code should generate word aligned addresses but sadly in Vivado 2018.2 it produces all zeros ...
In 2017.4 worked well.
class Bus;
    rand bit [15:0] addr;
    rand bit [31:0] data;
    constraint  word_align {addr[1:0] == 2'b0;}
endclass
module test2();
    Bus bus = new;
    initial
        repeat (50) begin
            if ( bus.randomize() == 1 )
                $display ("addr = %16h data = %h", bus.addr, bus.data);
            else
                $display ("Randomization failed.");
        end
endmodule
Produced output:
addr = 0000000000000000 data = 37b1b363
addr = 0000000000000000 data = f9d18e47
addr = 0000000000000000 data = f25cf357
addr = 0000000000000000 data = 938318f0
addr = 0000000000000000 data = c20bc5d0
addr = 0000000000000000 data = dd783a85
sunilku
hi @ronagyl_adi,
Randomization is not working if we write constraint to set value '0' to part select of random variable. If we set constraint for any other value other than zero, it is working. Issue reported to the factory.
Sunilkumar
ronagyl_adi
Hi @sunilku
From what I see the randomization does not work at all in case of part selections.
when I set  constraint  word_align {addr[3:0] == 4'd8;} the rest of the bits are not randomized, the whole addr gets the value of 8 just like in case of zero;
when I set  constraint  word_align {addr[3:0] == {1'b1,3'b0};} randomization fails, this seems to be another issue.
Please can you detail what you mean by: "If we set constraint for any other value other than zero, it is working."
Laszlo
sunilku
Hi @ronagyl_adi,
I do see the same behavior for the part select of random variable in constraint block. I suggest you not to use part-select until this issue is fixed.
Sunilkumar
