04-20-2020 08:30 PM
We are working on trying to simulate a 32 Bit Floating Point Multiplier. I am attaching the prompt and our code files. We really need help understanding how to create the test code. The test code that I am attaching will need to be modified to work with my design code. The design code hopefully works, but I may need some help debugging. I keep getting a few errors. I could really use some help. It all needs to be written in VHDL.
Attached:
1. Prompt
2. My Design Code
3. Test Code Model
04-20-2020 11:51 PM
You dont say what the problem is...
NOtes:
1. Your main_control process is missing F1, F2, multout from the sensitivity list.
2. In the Fmult_test.vhd, your stim_proc waits for clk_periods - so it will change just before the clock. You need to synchronise to the clock:
wait until rising_edge(clk); -- instead of wait for CLK_period;
04-21-2020 03:27 AM
Thank you for the help with that however the problem is in the prompt. But I have copied it here for your convenience
Below is what I am working on. I need to set up my test bench to simulate this data. It needs to work with my design code. That is the problem. I can't make it work.
c) Write a complete VHDL model for the multiplier (use at least two processes).
d) Simulate for the following test data (using test vector arrays in the testbench):
25.25 x -2.5 = -63.125
0 x 25.25 = ?
-7.5 x -7.5 = ?
04-21-2020 05:25 AM
The prompt doesnt have any problems - only an assignment.What problems are you having specifically? "I cannot make it work" is not really a problem we can answer. Why doesnt it work? what do you expect? what is actually happening? have you simulated? does the simulation run? are the inputs what you expected?
