7 Series GTX: GTX simulation consumes time although GTX it is in reset/no clock input
I used "7 series FPGAs Transceivers Wizard (3.6)" to generate a GTX transmitter (i.e. I checked button <RX off>). To speed up simulation, I wanted to hold the GTX in reset/no clock while the test case does some other initialization.
I realized, that GTX still consumes a lot of time although it is in reset and it has no input clock. The "Simprofile Report" states that there is an instance "B_GTXE2_CHANNEL_INST.SHIP.SHELL.BUT.Ichannelcore.Ichannelcore.Ichpmatop.Ichrxtop.Irxcore" which seems to be running, but I used "RX off".
Is there a way to stop this by setting dedicated inputs or may be by forcing an internal signal?
Best regards,
Heiner Wiese
