Anonymous
Not applicable
A long time to wait sub-compile when use xsim(vivado 2012.4 )
My design is operate on vivado 2012.4.
In RTL code there are ddr3 , fifos , axi-interconnetors that generated in vivado.
simulation sequecen is ->
1, simulation settings is defult
2, click [Run Simulation] in vivado
after this , tools begin to complie library .the xelab.log is shown as below
Compiling module work.FPGA_K7_TOP
Compiling module work.c0_ddr3_model_default
Compiling module work.c1_ddr3_model_default
Compiling module work.c2_ddr3_model_default
Compiling module work.c3_ddr3_model_default
Compiling module work.TB_TOP
Compiling module work.glbl
Waiting for 279 sub-compilation(s) to finish...
From this status to start xsim about  40 minutes, it's too long to simuate my designs
After investigation, I found that the number of sun-compilation is increment when used ip-core in design ,that means long time to wait . could anyone tell me the reason ?
I face the same problem under vivado 2013.2. Did you found a reason and solution ?
Which OS are you using?
And the RAM installed on the machine?
I have the same issue. I am using AXI4 ddr2 memory interface (with FFM simulation model),  AXI4 interconnect and my own RTL logic.
Running Vivado 2013.2 on Windows 7 64-bit with 8GB, i7-2600 CPU, 3.8GHz.
Every time I “Run Simulation” the IP cores and the full design are recompiled even though they have not been changed. Is there any way to avoid recompilation for cores and logic blocks that have not been changed?
Hello Everyone,
There is a roadmap plan of re-incorporating -incremental switch in future which would prevent re-compilation of already compiled modules. It would be similar to -Mupdate in VCS or -incr in Modelsim.
Currently it is not possible to prevent recompilation of files while re-running simulation. Our Development team is working on the same.
Debraj
Thanks Debraj,
It would be great if you could update the thread when this feature is available.
It already takes 15 minutes to compile my current design and it is only a small part of the whole design.
Unfortunately test benching smaller blocks is not an option at this stage.
Vlad
Sure Vlad, I would keep track of this and update this post.
Debraj
It is in the pipeline:
http://www.xilinx.com/support/answers/57239.htm
Just wondering if any progress has been made here? I am still experience long pre compile times in 2013.4 . Its a real bottleneck in doing any IP core designs on this platform.
Jon.
This is not in for 2014.1. But 2014.1 has runtime improvements for the tool which can be tested.
Debraj
Hi debrajr,
Is there any update on the incremental compilation feature?
Sc
I've just installed Vivado 2014.2 and this problem seems to be still present...when will the incremental compilation be available?
Thank you, Christophe
There is a lot of push for incremental compile even from our Sales folks and I would add your comments also to that. Currently it is not available but lets hope for that in the future release. If I get any info on the release date I would post here.
Debraj
Has any progress been mode here? I recently started using Vivado 2014.2 and am experiencing these same exhaustive comilation times.
It seems this problem will remain unresolved for WinXP users since Vivado no longer supports this OS, starting from v2014.4. :( Too bad.
For the Vivado 2014.4 release, Windows XP will no longer be supported. This is due, in large part, to Microsoft’s termination of Windows XP support.
Thanks,Vijay
Hi!
Just wondering if there are any news with that.
Im using 2015.1 and also expirenced these simulation log run due to reompiling...
Thank you
If there is no source code changes and no need to compile the code then you can skip compilation during re running simulation now with a TCL parameter:
set_property SKIP_COMPILATION 1 [get_filesets sim_1]
Debraj
Does the simulator has an option to compile only the changes?
I mean if the change is very small and only in a small part in the design, does the tool compile all again?
thanks
You are looking for incremental compilation in Vivado Simulator, which is not yet supported so even if you do small change in design, it will compile the complete design.
But if your change is on test bench level related with some vector that you are driving, you can achieve the same functionality by TCLcommand  itself and in that case, you won't have to compile the design again.
--dhiRAj
