A simulation waveform question
Can anyone tell me what is the answer for this question? I am not sure whether it is A2 or A3.
Best wishes
Re: A simulation waveform question
@muzaffer@thakurr
Thanks for the help.
I did a simulation today. However, I found out that the A2 or A3 is dependent on where does the first flip-flop get its input.
If it gets its input from the testbench directly, the waveform looks like A2. See signal a,b,c, ignore d:
If it gets its input from the previous flip-flop, the waveform looks like A3. Assume a is the previous flip-flop, see signal b,c,d:
Anyone know why?
Best wishes
Teacher muzaffer
@d4223738 we really don't want to do your homework for you. But I have a clue for you: what would the waveform be at the wire between Q of the first flop and D of the second flop? If you can answer this, then ask what is the waveform at A again.
Hi @d4223738
Answer should be A2 as A should propagate till D with the gap of one clock cycle.
Rohit
Rohit
Hi @thakurr
Thanks for the reply.
I am wondering do I need to consider timing violation?
Input A goes high at the same time the clock goes high.
Best wishes
Teacher muzaffer
@thakurr are you sure? I think it is worth firing up a simulator and checking.
Hi @d4223738
 It is worth writing a test bench and simulate. Here is the wave form which hope clears your doubt.
Also timing voilation should not be ignored anyway. Timing engine in Vivado make sure that your design is perfectly analyzed and all the hold and set up requirement are strongly met.
Rohit
Rohit
@muzaffer
Thank you for your advice. It was actually worth doing.
Rohit
Rohit
Teacher muzaffer
@thakurr can you please show the waveform on the net between Q of first flop & D of second flop in addition to A &  C nets?
@muzaffer@thakurr
Anyone know why?
Best wishes
Teacher muzaffer
@d4223738 the question to ask yourself is "what happens if a flop receives a change at its input at delta before clock?" In your "input from the testbench directly" case, waveform a & b are (almost) identical. Again ask yourself if this is a physically realizable DFF behavior. Another question is "in a real circuit where would the first flop get its input?" and in a related way "how should the testbench generate proper input to device under test?"
I hope these questions help you answer your question.
