AXI IP Module not found in simulation - Testcase
Hi folks,
  I've updated to 2018.2.2 last week and a new issue has popped up during behavioral simulation. The full design builds to a bitfile without any issues.
  In a nutshell, any AXI IP fails to compile during simulation with a similar message:
ERROR: [VRFC 10-2063] Module <axi_clock_converter_v2_1_16_axi_clock_converter> not found while processing module instance <inst> [/home/pcarr/Work/Pivotal/test-build/vivado/test_axi_ip/test_axi_ip.ip_user_files/bd/axi_ic/ip/axi_ic_auto_cc_0/sim/axi_ic_auto_cc_0.v:194]
ERROR: [XSIM 43-3322] Static elaboration of top level Verilog design unit(s) in library work failed.
  I have included a small testcase with a simple AXI interconnect that shows the error message every time. Sourcing the test_axi_ip.tcl recreates the project with a BD including the interconnect. Attempting to run a behavioral simulation shows the message above.
  The .zip file includes the test_axi_ip.tcl and the axi_ic.tcl scripts. To run, in Tcl shell please enter:
  > source test_axi_ip.tcl
Any pointers will be greatly appreciated.
-Pat
https://tuxengineering.com
Re: AXI IP Module not found in simulation - Testcase
The issue is known in 2018.2.2 and may be workaround by disabling the use of precompiled IP libraries.
The Tcl command that worked around it is:
set_property sim.use_ip_compiled_libs 0 [current_project]
Credit to @paulleons: https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-example-design-simulation-error/m-p/915050/highlight/true#M24323
-Pat
Folks,
  I can confirm this issue happens on 2018.2.2, but doesn't happen in 2018.2 or 2018.2.1.
  There's another user with the same duplicate issue: https://forums.xilinx.com/t5/Simulation-and-Verification/ERROR-VRFC-1-2063-Module-not-found-with-Vivado-2018-2-2/td-p/918041
-Pat
@graces
  I see that you mentioned a known simulation bug in 2018.2.2 regarding pre-compiled IP missing in installation directory.
  Can the issue on this thread be related to that known bug?
-Pat
-Pat
Yes, that should be the cause.
Compiling the IP static files at run time is one workaround.
