AXI Interconnect in Block Design -> how to simulate?
Hi All,
I have a Vivado Project, which consists of a Block Design and RTL files.
The Block Design consists of Zynq and AXI Interconnect.
I want to simulate the RTL along with AXI Interconnect ... How can I do so? The AXI Interconnect is a part of the Block Design... Is there a way to create an HDL wrapper for IP, which is a part of Block Design?
Thank you!
Re: AXI Interconnect in Block Design -> how to simulate?
Hi @ldm.eth ,
Create the HDL wrapper for the block design and then the AXI inter connect signals will come show in RTL. to Create HDL wrapper right click on BD and click create HDL wrapper.
Best Regards,
Srikanth
OK, but my Block Design includes both the Zynq & AXI Interconnect where Zynq drives the AXI Interconnect input ports... So, if I'll create an HDL Wrapper, it will only has the Zynq's ports and output ports of AXI Interconnect (no input ports of AXI Interconnect will be present in the HDL Wrapper).
So, what's the solution? How to simulate my design by driving the AXI Interconnect ports (I'd like the AXI Interconnect ports will be driven by TestBench and not by Zynq)?
Hi @ldm.eth ,
I'm not clear on your use case here
If you want to simulate an AXI Interconnect that isn't driven by the Zynq, then why not copy and paste the one you have into a new Block Design and create a wrapper on that?
You can get access to the internal signals. If you open the Simulation Sources and drill down below the block design you will see the RTL for the design.
You could then wrap this in a test bench
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
