n-kei
About the Vivado simulator VHDL error log
Please tell me about the error log of vivado simulator.
I entered the attached source code into the vivado simulator and ran the simulation.
Then I got the attached error log.
Is there a way to avoid the error without changing the attached source code number 1000000000000?
If there is a way, please tell me how to do it.
I will really appreciate if I can be given answer.
Thank you very much.
K.Nishimura
richardhead
1000000000000 is outside of the range of XSIM's integer implementation (nearly 32 bits)
Can you post more of the code and explain exactly what you're trying to do? For example, what is this "Frequency" type?
