Observer rayhoare
Adding collapsed groups to ISim with tcl
Hello all,
I can successfully add groups to ISim via tcl with the code below:
## add Fifo_IN's
set Fifo_r72_IN_id [group add "Fifo_r72_IN"]
set Fifo_r64_IN_id [group add "Fifo_r64_IN"]
set Fifo_r32_IN_id [group add "Fifo_r32_IN"]
set Fifo_r24_IN_id [group add "Fifo_r24_IN"]
wave add -into $Fifo_r72_IN_id -radix hex /top/Fifo_r72_IN/
wave add -into $Fifo_r64_IN_id -radix hex /top/Fifo_r64_IN/
wave add -into $Fifo_r32_IN_id -radix hex /top/Fifo_r32_IN/
wave add -into $Fifo_r24_IN_id -radix hex /top/Fifo_r24_IN/
However, I'd like the groups to be collapsed when I add them.  Currently, they are all added as expanded groups and it makes a mess of a signal-list on the screen.
Is there any configuration or settings parameter I can set so that when groups are added via tcl, they are added as collapsed groups?
Re: Adding collapsed groups to ISim with tcl
There is no TCL command for that but after creating the groups and adding signals, click inside the Waveform Window and do a CTRL-A, this select everything in the window. Right click and select Collapse. It collapses all the groups.
Debraj
