Visitor hatsuse
After run simulation, Active window is always switched for RTL code view.
I run simulation by vivado simulator (2018.2).
After running simulation have finished ,  active window is forcibly switched for test bench top code view (that is described $finish )
How do I always pin the waveform view on the top?
Super Soya
Visitor hatsuse
Re: After run simulation, Active window is always switched for RTL code view.
I have solved this topic.
When RTL code window set to floating window, the waveform window is displayed on the top.
This way can only be used by running simulation from Relanch sim button or Restart Run All button.
Super Soya
Visitor hatsuse
Super Soya
