03-26-2018 11:27 AM
I am using wedpack ISE, spartan 3
I have declared an array signal in my code as follows:
When simulating my code:
couldn't each address of this array be writen (modified) by different procedures?
There are no erros or warning when I compile my code
any suggestions?
Thank you
Fausto bartra
03-26-2018 12:06 PM
Try switching your memory declaration from a signal to a shared variable. That should get rid of the conflicts in simulation.
03-26-2018 12:20 PM
Please post the code, it is difficult to tell whats going on without a reference.
Points to note: In VHDL, each element of an array IS a separate object, so each element can be written from a separate process, unless there is a loop involved somewhere. BUT, this will NOT infer a RAM.
@jmcclusk A shared variable is only likely to mask the problem if there are multiple drivers in the code, and create race conditions during simulation. A shared variable should only be used if you are trying to infer write-first ram. Otherwise I highly recommend you use a signal, exactly for the reasons the OP is having problems with.
03-26-2018 12:33 PM
Voyager:
thank you it works
Just one problem, ISIM does not support variable tracing
thanks
Fausto Bartra
03-26-2018 12:45 PM
Richard:
here is my code: I have trimmed as much as I could to show where the problem is
two processes access the same array FpgaReg but different locations
Thank you in advance
type Array256x8 is array (0 to 255) of std_logic_vector(7 downto 0);
signal FpgaReg : Array256x8 := ((others => (others => '0')));
-- MCU Interface
McuInterface: process(CLK)
begin
if falling_edge(CLK) then
if (bufMCU_CSn = '1') then -- When CSn is HIGH, state machine gets reset
FpgaReg(CONV_INTEGER(ADDR_FPGA_VERSION_HIGH)) <= VER_HIGH;
else -- CSn is LOW
case McuState is
when FpgaWrite =>
FpgaReg(CONV_INTEGER(FpgaAddress)) <= bufMCU_D_IN; <-- if FpgaAddress changed with a value, no problems
end if;
end process McuInterface;
KpDebounce: process(CLK)
begin
if rising_edge(CLK) then
if P10ms = '1' then
case KeypadDebState is
when FoundKey =>
-- flag MCU
FpgaReg(CONV_INTEGER(KP_LED))(3 downto 0) <= LastKB; <-------------- this change shows as "X red colored waveform"
when others =>
end case;
end if;
end if;
end process KpDebounce;
03-26-2018 03:25 PM
Ok, so the only answer here is to use a shared variable. What do you expect to happen when both processes write to the same address at the same time? The VHDL shows the correct behaviour with XXXs, as it has no idea which signal wins, so you will get XXX.
A shared variable will avoid the Xs, but you are at the mercy of a race condition on a write to both locations at the same time.
