kp1998_
Array
Hello
For a given condition i want to store few values of a given array into another array but it is shwoing error. Please help with this.
Error it is showing is -
ERROR: [VRFC 10-1243] port array1 must not be declared to be an array [D:/Prog/butterworth_filter/butterworth_filter.srcs/sources_1/new/median_filter.v:51]
ERROR: [VRFC 10-1040] module median_filter ignored due to previous errors [D:/Prog/butterworth_filter/butterworth_filter.srcs/sources_1/new/median_filter.v:21]
Thank you
Neha
dror_m
please share the code
rshekhaw
Hi @kp1998_ ,
Please check this AR# link:
https://www.xilinx.com/support/answers/52934.html
Raj
kp1998_
Hello i am sharing a part of my code -
reg [7:0]dat0,dat1,dat2,dat3,dat4,dat5,dat6,dat7,dat8;
always @(posedge clk)
begin
dat0 <= A0;
dat1 <= A1;
dat2 <= A2;
dat3 <= A3;
dat4 <= A4;
dat5 <= A5;
dat6 <= A6;
dat7 <= A7;
dat8 <= A8;
end
integer i,j;
reg [7:0]temp;
reg [7:0]array[0:8];
output reg [7:0]array1[0:8];
always @*
begin
array[0] = dat0;
array[1] = dat1;
array[2] = dat2;
array[3] = dat3;
array[4] = dat4;
array[5] = dat5;
array[6] = dat6;
array[7] = dat7;
array[8] = dat8;
for (i = 9; i > 0; i = i - 1) begin
for (j = 0 ; j < i; j = j + 1) begin
if (array[j] > array[j + 1])
begin
temp = array[j];
array[j] = array[j + 1];
array[j + 1] = temp;
end
end
end
end
begin
out0 <= array[0];
out1 <= array[1];
out2 <= array[2];
out3 <= array[3];
out4 <= array[4];
out5 <= array[5];
out6 <= array[6];
out7 <= array[7];
out8 <= array[8];
end
genvar k;
generate
for (k = 0;k < 9;k = k + 1) begin
always@(posedge clk)begin
if(array[k]!=0 && array[k]!=255)
array1[k]<=array[k];
end
end
endgenerate
Can you please check and tell whether its correct or not.
Thank you
Neha
kp1998_
Hello
How to convert the existing verilog code to system verilog in vivado software.
Is it possible to find length of one dimensional array using verilog.
Thank you
Neha
dror_m
there are 2 easy ways to covert the code to sv:
1. change the suffix to sv instead of v.
2. in the vivado, click the file and the in the properties check the checkbox of system verilog.
