jeremyward
Automated simulation library compilation for ModelSim SE 6.3f
What version of ISE supports automated simulation library compilation (wizard or command line or anything) for ModelSim SE 6.3f?  ISE 14.1 only supports ModelSim 6.6d or later. Compiling manually is a total pain.
graces
ISE 10.1 does. See Table 6-3 in the Simulation guide.
http://www.xilinx.com/itp/xilinx10/books/docs/sim/sim.pdf
graces
jeremyward
Awesome.  Thanks so much!
