BRAM Output XXX value
Unable get output value at BRAM single port ram v7.3
attached is a Simulation screenshot
BRAM initialised with .COE file
Re: BRAM Output XXX value
reset_n is x,
Hi @verilog_bee
You forget to add the simulation snippet. Please share that.
Please share the .xci/.xco (IP configuration) file and .coe file and let us know which VIVADO/ISE version you are using.
educated guess,
 you have one or more of th econtrol inputs to the ram as 'x' ,
   you need to define all control inputs, else yo uwill get a X on the output.
Using ISE 14.7 BRAM v7.3
WARNING: File "E:/designs/sls/xilinx/local_repo/project_directory/ISE_14_7/bram_interface_ise/bram_interface_top.v" Line 29. For instance DUT/bram_inst/, width 1 of formal port wea is not equal to width 2 of actual signal wea.
WARNING: File "E:/designs/sls/xilinx/local_repo/project_directory/ISE_14_7/bram_interface_ise/bram_interface_top.v" Line 31. For instance DUT/bram_inst/, width 8 of formal port dina is not equal to width 16 of actual signal dina.
WARNING: File "E:/designs/sls/xilinx/local_repo/project_directory/ISE_14_7/bram_interface_ise/bram_interface_top.v" Line 35. For instance DUT/bram_inst/, width 8 of formal port doutb is not equal to width 16 of actual signal doutb.
WARNING: File "E:/designs/sls/xilinx/local_repo/project_directory/ISE_14_7/bram_interface_ise/old_tb/bram_interface_tb.v" Line 27. For instance bram_interface_tb/DUT/, width 2 of formal port wea is not equal to width 1 of actual variable wea.
WARNING: File "E:/designs/sls/xilinx/local_repo/project_directory/ISE_14_7/bram_interface_ise/old_tb/bram_interface_tb.v" Line 30. For instance bram_interface_tb/DUT/, width 16 of formal port dina is not equal to width 8 of actual variable dina.
WARNING: File "E:/designs/sls/xilinx/local_repo/project_directory/ISE_14_7/bram_interface_ise/old_tb/bram_interface_tb.v" Line 35. For instance bram_interface_tb/DUT/, width 16 of formal port doutb is not equal to width 8 of actual variable doutb.
reset_n is x,
