belarbi_alex
Bad DLL Format when loading libxil_vsim.dll in modelsim
When I want to run Modelsim PE 10.5c with Vivado 2016.3, I have the following message :
Load of "C:/Xilinx/Vivado/2016.3/lib/win32.o/libxil_vsim.dll" failed: Bad DLL format
Failed to load PLI object file "C:/Xilinx/Vivado/2016.3/lib/win32.o/libxil_vsim.dll
I have replaced win64.o by win32.o just before running the command vsim  below :
vsim -voptargs="+acc" -pli "C:/Xilinx/Vivado/2016.3/lib/win32.o/libxil_vsim.dll" -L xil_defaultlib -L xpm -L unisims_ver -L unimacro_ver -L secureip -lib xil_defaultlib xil_defaultlib.tdc_ip_core_tb xil_defaultlib.glbl
I follow the AR# 53678, AR# 62210, AR# 64083 instructions, but I saw that the library are always compiled with nt64 format
I set set_property MODELSIM.64BIT 0 [current_fileset -simset] but I obtain the same result
thakurr
Hi @belarbi_alex
Can you check if this link helps:
https://forums.xilinx.com/t5/Simulation-and-Verification/Bad-DLL-Format-when-loading-libxil-vsim-dll-in-modelsim/td-p/550210
Rohit
Rohit
belarbi_alex
I have run the command line Vivado -m32 , this command isn't known
You can see the prompted message in the attached file
Is Vivado 2016.3 running for 32 bit architecture ?
 Thank you for your help
Best regards
