Anonymous
Not applicable
Behavioral models for PLL and SERDES
I have to simulate my XILINX FPGA project (VIVADO v2015.04) in CADENCE NCSIM (v15.20.008).
My idea is to port the FPGA RTL files and add some behavioral models (Verilog or VHDL) for the IPs I have used in the FPGA: IO buffers, SERDES and PLL. Are these behavioral models available, or do I need to do something different?
Bernardo
Voyager
Voyager
Hey @Anonymous,
Most of the Xilinx primitives are available in the unisim library and simulation libraries for 3rd party simulators can be built with compile_simlib. AR# 64083 has all the details.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Anonymous
Not applicable
Hi hpoerzl,
actually I cannot find CADENCE SimVision as an option for compile_simlib. These are my options:
* modelsim - Version 10.4b and later
* questa - Version 10.4b and later
* ies - (Linux only) Version 14.20.006 or later
* vcs_mx - (Linux only) Version J-2014.12-SP2 or later
* riviera - Version 2015.02 or later
* active_hdl - (Windows only) Version 10.2
It should be vcs_mx (?) but anyhow it is an option for running under Linux linux, while I am running Vivado in Windows.
Is this precompiled library available somewhere?
Voyager
Voyager
Hey Bernardo,
Maybe those answer records can help:
AR# 58890 Third Party Simulators - Cadence IES
AR# 58891 Third Party Simulators - Synopsys VCS​/VCS-MX
Not that I'd know of, but maybe there is ...
Best,
Herbert
