Binary Counter v12.0 SCLR not working
I generated a Binary Counter v12.0:
32-bit
increment value = 1
Loadable
Sync Threshold Output, Value = 1
down counter
SCLR
CE
SCLR overrides CE
Manual Latency = 1
Manual Feedback Latency = 1
Load Sense Active High
No matter the state of CE, or how many clocks, SCLR will not function to clear the count value.
Please advise.
Emmett
Never mind.
I found the problem, my bad.
Never mind.
Could you post the root cause? It may be helpful to other people.
Cheers,
Rafael.
