Black Box Warning when using component
Hello together,
I'm quiet new to VHDL programming so excuse me if I understood something wrong. I created some basic code I wanted to simulate. Here the code of file 1:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Hello_World is
    Port ( Inp1 : in STD_LOGIC;
           Inp2 : in STD_LOGIC;
           Outp : out STD_LOGIC);
end Hello_World;
architecture Hello_World_Arch of Hello_World is
begin
    Outp <= (Inp1 and Inp2);
end Hello_World_Arch;
File 2:
library IEEE;
entity Hello_World_TB is
end Hello_World_TB;
architecture Hello_World_TB_Arch of Hello_World_TB is
    component Hello_World_Comp
    end component;
    signal Inp1_Sig : STD_LOGIC;
    signal Inp2_Sig : STD_LOGIC;
    signal Outp_Sig : STD_LOGIC;
begin
uut: Hello_World_Comp PORT MAP (Inp1=>Inp1_Sig, Inp2=>Inp2_Sig, Outp=>Outp_Sig);
--uut: entity work.Hello_World(Hello_World_Arch) port map (I1=>I1, I2=>I2, Output=>Output);
process
begin
    Inp1_Sig <= '0';
    Inp2_Sig <= '0';
    wait for 100ns;
    Inp1_Sig <= '1';
    Inp2_Sig <= '1';
    wait;
end process;
end Hello_World_TB_Arch;
configuration Hello_World_TB_Config of Hello_World_TB is
    for Hello_World_TB_Arch
        for uut : Hello_World_Comp
            use entity work.Hello_World(Hello_World_Arch);
        end for;
    end for;
end Hello_World_TB_Config;
I create an component from an entity of another file. I always get the following warning:
In my source editor it's clearly linked to the other file:
Also the simulation isn't working, it's always not defined the output:
When I now use direct instantiation of the entity as following, the error is gone and the simulation is working.
What am I doing wrong with the component?
Thanks for your support!
Kind regards
Scholar richardhead
Re: Black Box Warning when using component
You've named the component
Hello_World_Comp
But the entity is actually called "Hello_World"
The Component name must match the entity so the mapper knows which entity to map the component to. The component is like a prototype. And also not required - if you can, stick with direct instantiation because missing ports are a syntax error which takes seconds to find, whereas missmatches between component and entity wont be picked up until elaboration, which may take several minutes for a large design.
Scholar richardhead
Hello_World_Comp
Thanks for the fast support! Now it is working but I keep using direct instantiation because it makes the code clearer in my opinion.
