01-24-2014 06:42 PM
I have previously reported this as bug for isim 14.7 and learned that there won't be any fixes in ISIM. As it turns out, there is the same bug in xsim, so here is an updated bug report:
The following module should return 3'b001:
module issue_017(y); output [2:0] y; assign y = &($signed(2'b11)); initial #10 $display("%b", y); endmodule
But xsim 2013.4 returns 3'b000 instead.
I get the the same bug when I replace $signed with $unsigned. The bug goes away if I do not use $signed or $unsigned or reduce the size of y. Somehow the size of y "leaks through" to the self-determined operand of the & reduce operator when used with $signed or $unsigned.
In my tests I have run this module with:
xvlog issue_017.v xelab -R work.issue_017
Crosscheck: Vivado 2013.4, XST 14.7, Quartus 13.1 and Modelsim 10.1d implement this correctly.
04-21-2014 11:28 PM
