simchask
C TB Failed, after XSIM completed
I manage to simulate my simple code with a testbench. After XSIM completes, I get these messages.
INFO: [COSIM 212-302] Starting C TB testing ...
ERROR: System recieved a signal named SIGSEGV and the program has to stop immediately!
This signal was generated when a program tries to read or write outside the memory that is allocated for it, or to write memory that can only be read.
Possible cause of this problem may be: 1) the depth setting of pointer type argument is much larger than it needed; 2)insufficient depth of array argument; 3)null pointer etc.
Current execution stopped during CodeState = DUMP_INPUTS.
You can search CodeState variable name in apatb*.cpp file under ./sim/wrapc dir to locate the position.
ERROR: [COSIM 212-360] Aborting co-simulation: C TB simulation failed.
ERROR: [COSIM 212-320] C TB testing failed, stop generating test vectors. Please check C TB or re-run cosim.
ERROR: [COSIM 212-4] *** C/RTL co-simulation finished: FAIL ***
command 'ap_source' returned error code
    while executing
"source C:/Users/Owner/DDRConst2/solution1/cosim.tcl"
    invoked from within
"hls::main C:/Users/Owner/DDRConst2/solution1/cosim.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
Finished C/RTL cosimulation.
Note that my main function always returns 0.
The test bench:
#include <stdio.h>
#include "DDRConst.h"
unsigned char mem[11];
unsigned char s;
int main()
//#pragma HLS INTERFACE s_axilite depth=200000 port=mem bundle=mem_b
	DDRConst(mem,10, 5);
	for (int i=0; i<11; i++)
		printf("mem cell %X: %X \n", i, mem[i]);
	return(0); //Will always report failure otherwise
simchask
Solved my own problem.
Very annoying - compiler keeps warning that if the depth of the master port is insufficient there will be problems. So I kept increasing it until it reached 2000000.
When I reduced it to 100 the warning stayed but the error disappeared.
simchask
yaya04
I've seen similar error and solved it by following your solution.
It seems that the depth of the interface should be the size of the array.
Thanks anyway.
Chaeeon.
