Can i see FIFO IP content?
The first image is my fifo and I marked the place I wanted to see. The second image is xilinx ip fifo. but I couldn't see FIFO memory content. Is there a way do this?
Re: Can i see FIFO IP content?
Hi @fpgatr
No. We dont have provision to check the FIFO content.
May i know the background of this query ?  Are you seeing any abiguity with FIFO behaviour.
回复: Can i see FIFO IP content?
You may change elaboration option -debug_level from 'typical' to 'all' to enable more objects within IP.
How the memory element signal is displayed depends on how it is declared in IP models.
Scholar dpaul24
@fpgatr,
If you have the correct write and read logic on both sides of the FIFO, then for every wr_clk if the we_en is HIGH then data would be written to the FIFO. Then if the rd_en is working and rd_clk is supplied, then you should be seeing the data which you have written, dout.
Thats an alternative and time consuming way to see the contents.
FPGA enthusiast!
All PMs will be ignored
