Can't initialize memory
I'm learning how to build a simple MIPS SoC on Basys3 board, and am having a problem initializing my memory.
The design source hierarchy is as follows.
The top.v code:
module top #(parameter WIDTH = 8, REGBITS = 3)(
    input                          clk, reset,
    input          [WIDTH-1:0]     swu,		//upper 8 switches
    input          [WIDTH-1:0]     swl,		//lower 8 switches
    input          [4:0]           btn,		//5 push buttons
    output  reg    [3:0]           an,		//digit selection for 7-seg display
    output  reg    [WIDTH-1:0]     seg,		//seg selection for 7-seg display
    output  reg    [WIDTH-1:0]     ldu,		//upper 8 LEDs
    output  reg    [WIDTH-1:0]     ldl);	//lower 8 LEDs
    wire   	         memread, memwrite;
    wire    [WIDTH-1:0]  adr, writedata;
    wire    [WIDTH-1:0]	 memdata;
   // instantiate devices to be tested
   mips	 #(WIDTH, REGBITS) dut(clk, reset, memdata, memread, memwrite, adr, writedata);
   // external memory for code and data
   memory_io #(WIDTH) mem_io(clk, memwrite, adr, writedata, memdata);
endmodule
The memory_io.v uses memory-mapped I/O solution:
module memory_io #(parameter WIDTH = 8)(
   input   			clk,
   input 			memwrite,
   input	[WIDTH-1:0]     adr,
   input        [WIDTH-1:0]     writedata,
   output   reg	[WIDTH-1:0]     memdata,
   input        [4:0]           btn,
   reg  [31:0] 	RAM [(1<<WIDTH-2)-1:0];
   wire [31:0] 	word;
//   initial
//      begin
//         $readmemh("D:/Computer/mips_8/memfile.txt", RAM, 4);
//      end
initial begin RAM[4] <= 32'h0000_0008; RAM[8] <= 32'h0000_0004; RAM[12] <= 32'h0000_0002; RAM[16] <= 32'h0000_0001; RAM[20] <= 32'h8001_0000; RAM[24] <= 32'h8002_0004; RAM[28] <= 32'h8003_0008; RAM[32] <= 32'h8004_000C; RAM[36] <= 32'h8005_0010; RAM[40] <= 32'h1085_0002; RAM[44] <= 32'h0043_0822; RAM[48] <= 32'h0800_000E; RAM[52] <= 32'h0043_0820; RAM[56] <= 32'hA001_0000; end // read and write bytes from 32-bit word always @(posedge clk) if (memwrite) if (adr >= 8'hf0) case (adr) 8'hf9: an <= writedata[3:0]; 8'hf8: seg <= writedata; 8'hf1: ldu <= writedata; 8'hf0: ldl <= writedata; endcase else case (adr[1:0]) 2'b00: RAM[adr>>2][7:0] <= writedata; 2'b01: RAM[adr>>2][15:8] <= writedata; 2'b10: RAM[adr>>2][23:16] <= writedata; 2'b11: RAM[adr>>2][31:24] <= writedata; endcase assign word = RAM[adr >> 2]; always @(*) if (adr >= 8'hf0) case (adr) 8'hf4: memdata <= {3'b000, btn}; 8'hfc: memdata <= swl; 8'hfd: memdata <= swu; endcase else case (adr[1:0]) 2'b00: memdata <= word[31:24]; 2'b01: memdata <= word[23:16]; 2'b10: memdata <= word[15:8]; 2'b11: memdata <= word[7:0]; endcase endmodule
And my testbench code:
`timescale 1ns / 1ps
module mips_8_tb #(parameter WIDTH = 8, REGBITS = 3)();
    reg     		clk;
    reg                 reset;
    reg     [WIDTH-1:0] swu, swl;
    reg     [4:0]       btn;
    wire    [3:0]       an;
    wire    [WIDTH-1:0] seg, ldu, ldl;
    mips        #(WIDTH, REGBITS)    dut_tb(clk, reset, memdata, memread, memwrite,
                                            adr, writedata);
    memory_io   #(WIDTH)    mem_io_tb(clk, memwrite, adr, writedata, memdata,
                                      swu, swl, btn, an, seg, ldu, ldl);
    initial
        begin
            reset <= 1; #22 reset <= 0;
        end
always begin clk <= 0; #5; clk <= ~clk; #5; end endmodule
I added RAM to wave window, but got the following wave:
Thanks for your answer! :)
Re: Can't initialize memory
Hi cmpt_design,
You would get the waveform as shown in the attached file.
From the waveform , it is clear that the RAM values which are initialized are shown as green and those which are not initialized are shown as red. As, RAM is of type REG the default value is X.
Please initialize the remaining values of RAM so that the register is not left uninitialized.
Thanks & Regards,
A.Shameer
I noticed there's a correct value: a0010000, among 2 others, but there're 15 values I'd like to pre-store into my memory. And also, why is the color red instead of green?
If you want 16 addresses you have to work with an address width of 5.
module mem #(parameter WIDTH = 5)(
Also, your RAM assignment must be continuous, you must assign values to each cell of the array, like this:
    initial
       begin
          RAM[0]    <=  32'h0000_0008;
          RAM[1]    <=  32'h0000_0004;
          RAM[2]   <=  32'h0000_0002;
          RAM[3]   <=  32'h0000_0001;
          RAM[4]   <=  32'h8001_0000;
          RAM[5]   <=  32'h8002_0004;
          RAM[6]   <=  32'h8003_0008;
          RAM[7]   <=  32'h8004_000C;
          RAM[8]   <=  32'h8005_0010;
          RAM[9]   <=  32'h1085_0002;
          RAM[10]   <=  32'h0043_0822;
          RAM[11]   <=  32'h0800_000E;
          RAM[12]   <=  32'h0043_0820;
          RAM[13]   <=  32'hA001_0000;
I have added the values you used, you have to add values for RAM[14] and RAM[15] so they won't be left undefined.
Hope this helps
Avi Chami MSc
FPGA Site
Hi cmpt_design,
Thanks & Regards,
A.Shameer
You're absolutely right!
Yeah, I got it, thx!
Hi @cmpt_design,
Please close the thread my marking the appropriate post which helped you with the resolution as "Accepted solution". This will help the future users.
Sravanthi B
Thanks & Regards,
Sravanthi B
