Can't run ISIM and I don't understand the error: ERROR:ProjectMgmt:387
Launching ISim simulation engine GUI...
"E:/Documents and Settings/Jamil/My Documents/Downloads/exp5/ppm_isim_beh.exe" -gui -tclbatch isim.cmd  -wdb "E:/Documents and Settings/Jamil/My Documents/Downloads/exp5/ppm_isim_beh.wdb"
ERROR:ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'invalid command name "dpm_fail"'.
Tcl_ErrnoId: unknown error
Tcl_ErrnoMsg: No error
_cmd: ::xilinx::Dpm::dpm_chTransformExecute dpm_isimRunExe $piThisInterface
errorInfo: invalid command name "dpm_fail"
    while executing
"dpm_fail "ISim simulation engine failed to launch" "
    (procedure "dpm_isimRunExe" line 423)
    invoked from within
"$sCmd $iTransformInstance $sCmdArgs"
    (procedure "dpm_chTransformExecuteEngine" line 101)
    invoked from within
"dpm_chTransformExecuteEngine $sFlowProc $iInterface $bRunTransformWithEmptyInputSet "
    (procedure "::xilinx::Dpm::dpm_chTransformExecute" line 3)
    invoked from within
"::xilinx::Dpm::dpm_chTransformExecute dpm_isimRunExe $piThisInterface"
 This is the output in the console when I try to run ISIM, with a behavioral simulation. I don't understand what the error is or how I can fix it. As far as I know, I didn't receive any errors or unexpected warnings when I ran a synthesis, so I don't know why this is happening. (This file was working before for someone else, and I didn't make any changes in the schematic).
Tags (3)
Re: Can't run ISIM and I don't understand the error: ERROR:ProjectMgmt:387
Try Project > Cleanup Project Files or recreate a new project.
I'm Having the same problem, I've cleaned the project and remade it, but the error persists. I'm using ISE 13.1, and I'd really appreciate other answer than: this issue is solved in the next ISE version.
What if you run simulation alternatively in command line?
1. Open "ISE Design Suite Command Prompt" from Start > Xilinx ISE Design Suite xx > Accessories
2. Cd to your project directory
3. ppm_isim_beh.exe -gui -tclbatch isim.cmd
