artg
Can we force signals to '1' or '0' in the wave window of the vivado simulator ?
Hi All,
I used to work with the ISIM simulator of ISE and in this simulator it was possible to force signals to '1'  or '0' during a simulation when you paused it.
Now I use the Vivado simulator is there a simular option for this or is it not possible ?
vemulad
Yes this is possible.
In the "objects" window of simulation GUI if you right click on the signal you can find "Force constant" option. See below.
Deepika.
Deepika.
vemulad
Deepika.
Deepika.
pulim
To addon to Deepika if you want to force a clock signal you can use the Force clock option which is below the Force Constant option.
The same topic is discussed here,
http://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-2014-2-Simulation-question/m-p/493582#M10490
anusheel
Check below link
http://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-XSIM-missing-features-versus-ISE-ISIM/td-p/400987
Anusheel
Search for documents related to your device and tool before posting query.
Please mark the post as an answer "Accept as solution" in case it helped to resolve your query.
Give kudos for accepted solution.
artg
thanks for all the replies, I find this a very useful function for some quick tests.
