Cannot annotate SDF file in timing Sim when using I/OSERDES
Hi all,
I used a lot of ISERDES and OSERDES in a Virtex Ultrascale+ device in my test design. I made a simple test project using Vivado2018.2 and tried to run timing simulation. The project could generate the bitstream and did functional simulation successfully, but always failed when doing timing simulation(post sythesis and pos implementation). Below is the error gave by Vivado.
In elaborate.log in SIM:
    Completed static elaboration
    ERROR: [XSIM 43-3221] (SdfError)Error while parsing sdf file "lvds_top_time_impl.sdf" Line 24874: syntax error,     unexpected IOPATH, expecting $end.
    ERROR: [XSIM 43-3915] Encountered a fatal error. Cannot continue. Exiting...
I don't know whether the .sdf file has syntax error or there is any mistake in my design. By the way, the same design coule do timing simulation if I using a Ultrascale(not Ultrascale+) device.
Attachments is the project and the lvds_top_time_impl.sdf.
My project could run timing simulation if I remove all the ISERDESE3.
It was clear that the error came from ISERDESE3.
