Cannot complie simulation library for Questa Sim 10.1b
When running compxlibgui (ISE 12.4) to compile simulation library for Questa Sim 10.1b, it gives out message :
 "ERROR:Compxlib:368 - Compxlib does not support questa version 6.3b or prior releases. Parsing through the path setting on your system we have identified that you are using questa '2012.04'.
Please contact Mentor Graphics to upgrade to a supported simulator version. If the path setting is incorrect, please ensure that you are pointing to the latest version and re-invoke compxlib.
The list of supported simulator versions are listed in the Simulation Chapter of the Synthesis and Simulation Design Guide on http://www.xilinx.com.
Simulator 'questa' is ignored."
Thank you!
Re: Cannot complie simulation library for Questa Sim 10.1b
Please refer to Xilinx Answer 39072.
http://www.xilinx.com/support/answers/39072.htm
Thank you.
