Visitor simonsabato
Cannot define a value on xvlog command line in Windows command prompt
I seem to be unable to do something very simple:
C:\>xvlog test.sv
INFO: [VRFC 10-2263] Analyzing Verilog file "C:/test.sv" into library work
INFO: [VRFC 10-311] analyzing module test
C:\>xvlog --define A=B test.sv
ERROR: [XSIM 43-4316] Can not find file: B
This is on Windows 10, using both "new" and "legacy" consoles (properties->options).  Works just fine in Linux.  I think perhaps the various .bat wrappers that get called are not handling the "=".
Note that it seems to work if I add quotes:
xvlog --define "A=B" test.sv
Is this expected behavior?  I didn't see this in the docs (UG900 etc).  It's hard/impossible to find any command line example of defining a macro *to a value*  (there's lots of "-d MACRO" examples).
回复: Cannot define a value on xvlog command line in Windows command prompt
Yes, the behavior is specific in Windows.
As you've mentioned, please enclose the macro definition in quotes.
