Cannot find design unit xil_defaultlib.system_tb in library work located at xsim.dir/work
Hi all,
   I met the error "Cannot find design unit xil_defaultlib.system_tb in library work located at xsim.dir/work". I tried the posts on the forum to set Library, which cannot work. How to solve it? Thanks much.
Hello @zhengyudennis1
In the Sources window of Vivado, under sim_1, select the file. In the below properties window, change the library.Snapshot below:
FYI.. By default, the library is set to xil_defaultlib
Vinay
   Thanks for the reply. Should I change the library from "xil_defaultlib" to "work"?
If I change it to 'work', then it reports "[XSIM 43-3225] Cannot find design unit work.system_tb in library work located at xsim.dir/work.
". I am not sure what is wrong.
Hi @zhengyudennis1
Can you please share your project archive?
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
Sorry, I cannot do it, since it is a very big design. I searched on the website and the cause is the xil_defaultlib.system_tb is not generated. However, the syntax is correct for system_tb file. Do you know some other causes? Thanks.
Hi @zhengyudennis1,
What is the size of archived project file?
I can send you an ezmove link to share the archive project file.
Arpan
Arpan
@zhengyudennis1
Can you check .prj file and make sure this file is not missing? Refer below AR:
http://www.xilinx.com/support/answers/56685.html
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Hi @zhengyudennis1,
Is your issue resolved?
Please let us know if you need any further help.
Nupur
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
Yes, thanks.
Hi @zhengyudennis1,
Good to know that your issue is resolved. Plesae post the solution and mark it as accepted solution in the interest of other users.
Thanks,Vijay
