Anonymous
Not applicable
Cannot simulate post map and post route
I cannot run the simulation for post-map and post route designs. It runs fine for behavioural and post translate.
I get the following error -
# ** Error: (vsim-SDF-3250) netgen/map/my_sr4a_map.sdf(0): Failed to find INSTANCE '/UUT'.
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./my_sr4a_test.mdo PAUSED at line 8
Anonymous
Not applicable
Re: Cannot simulate post map and post route
I figured it out. The default instance label is UUT. I was using U1.
I had to make this change in the simulation properties --( In the processes window right click simulate post route simulation).
Anonymous
Not applicable
