Change simulation source in block design
Within a IP Integrator Block Design I would like to use the Xilinx PCIe core IP for synthesis/impl but for my simulation I want to replace it with an emulator. Is it possible to do this within the block design? Or do I need to create another simulation specific BD then?
If I select the IP, in the Source File Properties dialog I see that the 3 'Used In'  check boxes for Synthesis, Implementation and Simulation are all checked and greyed out so I cannot change those.
Thank you
Re: Change simulation source in block design
HI @ingmarhybriddsp ,
If you are trying to use different IP Sources in a BD for synthesis and Simulation. I would suggest you to create another BD and add the IP which you want to use fro simulation there.
