davekry
Classic "Error: Cannot find xxx in library xil_defaultlib" error
I am trying to use a package in xil_defaultlib in a testbench file.
So I tried:
using the work directory
tried changing to manual compile order as well as manual update
defining the package as IS_GLOBAL_INCLUDE
uncheck the xsim.elaborate.load_glbl* in the simulation settings
checked that it is listed in the .prj under ../project_1.sim/sim_1/behav/xsim
verified no errors in the .log files
the file is listed under the xil_defaultlib in the libraries tab, I have tried it listed in the design section and the simulation section
I am running vivado 2017.3
Any buddy have any ideas on what to try?  I attached the archive.
amaccre
Hi @davekry,
I ran the simulation from the project that you supplied and there is an error given over a file called DCSO.txt which it is trying to read and which has a hard path included.
ERROR: File c:/work/fpgas/cordic_test/project_1/project_1.srcs/sim_1/imports/rect2polar/Data/DCS0.txt is not open. Cannot call endfile on it
This can be seen in the tcl console when the simulation is run.
Let me know if this helps.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
