dmitry1417
Code Coverage -> how to?
Hi All,
How can I generate a Code Coverage report for Vivado simulations?
Where can I see some examples? .
Thank you!
vijayak
Hi @dmitry1417
Code coverage is not yet supported by Vivado simulator and is in roadmap.
Thanks,Vijay
vijayak
Hi @dmitry1417
Thanks,Vijay
austin
d,
There is documentation for code coverage of your sources for c/c++ using HLS (ug998).  Is that what your are looking for?  or is the coverage fort you verilog or VHDL (quite a different task)?
Austin Lesea
Principal Engineer
Xilinx San Jose
dmitry1417
Actually I need some indication how much my TestBench cover the RTL functionality.
The RTL is written in Verilog, TestBenches are also.
I'm using Vivado v2015.4 for my simulations.
nagabhar
hi @dmitry1417
As mentioned before by Vijay, this is not yet supported in Vivado.
You will have go  for a  third party simulator like Questa sim which has the code coverage analysis feature.
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
vijayak
Hi @dmitry1417
Hope that answers your query. Please close the thread by marking the solution in the interest of other users.
Thanks,Vijay
sanjivgarg
Has code coverage for Vivado simulator been added yet?
