ComMsgMgrException: type error near %s
I am using the block memory genrator to instiate a block ram in my design and when i attempt to simulate the design i get the following error:
ComMsgMgrException: type error near %s ; expected type %s: Invalid c_string in format.
ERROR: [VRFC 10-1472] type error near %s ; expected type %s
This error mentions nothing about the block ram generator or my code, but I know it is related to the block ram generator because when i remove the block ram from my code this error goes away.
I am not realy sure how to get around this. I have tried regenerating the output product for this block ram and even removed it from the project and put it back agian. I cannot find anything on the internet with this same error message....
Anyone else seen this?
Follow the steps below.
1. Set the "target language" to VHDL in project settings.
2. Right click on the IP and do "reset output products" followed by "generate output products". This will generate the template in vhdl language.
Deepika.
Deepika.
which simulator are you using? Also how are you instantiating the generated block ram? Did you use the instantiation template generated exactly?
Thanks for the reply
I am using ISIM or the default vivado simulator... not sure if that is called ISIM anymore.
My instantiation is shown below:
blk_mem_gen_0_inst : ENTITY work.blk_mem_gen_0
PORT map(
clka => clka,
ena => ena,
wea => wea,
addra => addra,
dina => dina,
douta => douta,
clkb => clka,
enb => 1,
web => 0,
addrb => Data_I,
dinb => dummy,
doutb => data_out_sig
I didn't get this instantiation from a template rather created it myself base on the toplevel "blk_mem_gen_0.vhd" in vivado.
In ISE there was feature that would create a instaition template for you but it seems this is missing in vivado... If there is a way to autogenerate and instatiion template in vivado i would like to know about it.
coregen gives you a instantiation template when you create the ip. It usually has an extension .veo. Checkout the directory where you put the IP.
You can find generated "Instantiation Template" under IP Source. Refer below snapshot:
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
ahh.
that is good to know but the instaition template is in verilog and i am using vhdl. I tried punching around to find out how to change the instiation template to vhdl, but cant seem to find that...?
My project is set to use VHDL, but it still is instiationing the template in verilog?
Deepika.
Deepika.
This seemed to solve the problem once i used this instation template.
Thanks All!
