Visitor larrypap
Compilation error in CAM memory cam_v5_1 and cam_v6_1
I use CAM memory cam_v5_1 from LogiCore (in ISE v10.1 SP3) and I have compilation error (in ISim).
ERROR:HDLCompiler:410 - "K:/IP3_K.12/env/Databases/ip/export/rtf/vhdl/src/XilinxCoreLib/cam_v5_1.vhd" Line 834. Expression has 16 elements ; expected 4
ERROR:Simulator:777 - Static elaboration of top level VHDL design unit tb_file_read in library work failed
When remove the CAM statement (my_CAM), works properly. When I put it, I have errors ….. any idea?
In .coe file I have the correct data
MEMORY_INITIALIZATION_RADIX=2;
MEMORY_INITIALIZATION_VECTOR=
00000000000000000000000000000000,
01000010000000000000000000000001,
00000000000000000000000000000000;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity TB_FILE_READ is
end TB_FILE_READ;
component cam2e
            port (
                                    clk: IN std_logic;
                                    din: IN STD_LOGIC_VECTOR(31 downto 0);
                                    busy: OUT std_logic;
                                    match: OUT std_logic;
                                    match_addr: OUT STD_LOGIC_VECTOR(3 downto 0));
end component;.
signal data_out_A:      std_logic_vector(31 downto 0) := (others => '0');
-- cam signals
signal s_asxeto: std_logic :='0';
signal s_nai_yparxei: std_logic :='0';
signal s_i_dieythinsi: std_logic_vector(3 downto 0);
my_CAM : cam2e
port map(
                                                clk                               => clk,
                                                din                               => data_out_A,
                                                busy                             => s_asxeto,
                                                match                          => s_nai_yparxei,
                                                match_addr                => s_i_dieythinsi
I have the same errors when use the cam_v6_1
ERROR:HDLCompiler:410 - "K:/IP3_K.12/env/Databases/ip/export/rtf/vhdl/src/XilinxCoreLib/cam_v6_1.vhd" Line 1241. Expression has 16 elements ; expected 4
Visitor larrypap
Re: Compilation error in CAM memory cam_v5_1 and cam_v6_1
Hi!
I found the problem!
In the beginning in my project I used the first  “Binary Encoded” in my_CAM (cam2e), the compile was successful!
When I use “Single Much Unencoded” and “Multi Much Unencode” (because I want to see results) the compile was again successful!
When I restored setting in “Binary Encoded” then the problem and the messages occurred
And remain there ………..  :/
Yes I know I can use encoder to find the address, but I prefer the first option “Binary Encoded”.
Thanks!!
