goahead97
Compile Simulation Libraries for Questa does not create any file on Compiled library location
Hello
I compiled simulation libraries for Questa Advanced  Simulator within Vivado as follows:
/home/x/workspace/vadd2_kernels/vivado_rtl_kernel/rtl_kernel_wizard_0_ex/rtl_kernel_wizard_0_ex.cache/compile_simlib/questa
/tools/Questasim/questasim/linux_x86_64
/tools/Questasim/questasim/gcc64
Nonetheless, after running Tools menu->Compile Simulation Libraries, I still cannot see the files of the compiled simulation libraries on the following folder. The folder is empty:
Moreover I get an error when I try to launch behavioural simulation with Questa:
And therefore I do not know how I can run a simulation with Questa successfully.
Do you know how to fix this problem?
graces
Did you observe any errors in running compile_simlib?
goahead97
Yes, I did. It seems my Questasim 2020.4 is not compatible with my Vivado 2020.2.2. Thanks
