eholtzclaw
Compiling Libraries
After compiling unisim, the .cxl.vhdl.unisim.unisim.nt64.log, in c:/questasim64_10.5/vhdl_src/unisim/unisim reads:
** Warning: (vcom-159) Mode option -64 is not supported in this context and will be ignored.
QuestaSim-64 vcom 10.4c Compiler 2015.07 Jul 20 2015
Start time: 09:35:40 on Aug 03,2017
vcom -source -93 -novopt -64 -work unisim -f C:\questasim64_10.4c\vhdl_src\unisim/unisim/.cxl.vhdl.unisim.unisim.nt64.cmf -f C:\questasim64_10.4c\vhdl_src\unisim/unisim/.cxl.vhdl.secureip_vhdl_unisim.unisim.nt64.cmf
-- Loading package STANDARD
###### C:\Xilinx2\Vivado\2017.1\data\vhdl\src\unisims\unisim_retarget_VCOMP.vhdp(45): `protect data_method = "AES128-CBC"
** Error: C:\Xilinx2\Vivado\2017.1\data\vhdl\src\unisims\unisim_retarget_VCOMP.vhdp(45): near "AES128-CBC": Unknown session key in protected region
###### C:\Xilinx2\Vivado\2017.1\data\vhdl\src\unisims\unisim_retarget_VCOMP.vhdp(46): `protect encoding = (enctype = "BASE64", line_length = 76, bytes = 2488512)
** Error: C:\Xilinx2\Vivado\2017.1\data\vhdl\src\unisims\unisim_retarget_VCOMP.vhdp(46): VHDL Compiler exiting
End time: 09:35:40 on Aug 03,2017, Elapsed time: 0:00:00
Errors: 2, Warnings: 1
graces
The vcom invoked is from Questasim 10.4c. Please upgrade to 10.5c and above, which is the compatible release with Vivado 2017.1.
