Conformal LEC support on Vivado tool
Is Vivado tool support LEC tool conformal similar to ISE?
Re: Conformal LEC support on Vivado tool
Hi @kamlesh.kumar ,
Yes it's supported.
As mentioned in the following AR#25007Xilinx supports only equivalency checking in the current ISE software. Cadence Encounter Conformal (9.1) is the supported tool with the latest ISE 14.7 release.
You have to convert generated netlist to readable netlist for LEC.
Here is a link for Command Line Tools
User Guide: https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/devref.pdf
Please let me know if you still need more assistance.
-Romisaa
Don't forget to reply, give Kudo and accept as solution
Hi Romisaa,
Thanks for your input. Is ISE 14.7 not support device Kintex Ultrascale+. No I think.
Kamlesh Kumar
Hi Kamlesh,
No, Xilinx ISE Design Suite does not, and will not, support UltraScale devices.
If you wish to target an UltraScale device, then you need to use Xilinx Vivado Design Suite: http://www.xilinx.com/products/design-tools/vivado/
For more information on what devices are supported in Xilinx ISE Design Suite, please see the Software Matrix: http://www.xilinx.com/publications/matrix/Software_matrix.pdf
-Romisaa
