Norian
Counter takes an unexpected value on initialization.
I would like my counter cpt to take the value of 0 at initialization but it takes the value 2:
Capture d’écran du 2021-05-22 22-22-23.pngI think this is due to the baudrate_clk process in my testbench but I don't know how to fix it.
This is what my testbench looks like:
-- Company:
-- Engineer:
-- Create Date: 15.05.2021 18:28:17
-- Design Name:
-- Module Name: tb_UART_RX - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity tb_UART_RX is
--  Port ( );
end tb_UART_RX;
architecture Behavioral of tb_UART_RX is
component UART_RX
    Port(clk, rst, RX: in std_logic;
        parity: in std_logic_vector(1 downto 0);
        timeout_value: in std_logic_vector(31 downto 0);
        error_parity,timeout: out std_logic;
        RXREG: out std_logic_vector(7 downto 0));
end component;
component baudclk
    Port ( clk, rst : in STD_LOGIC;
           baudrate_clk_ticks: in std_logic_vector(31 downto 0);
           baudclk : out STD_LOGIC);
end component;
signal sRX,clkbaudrate,serror_RX,stimeout,sclk: std_logic := '0';
signal stimeout_value: std_logic_vector(31 downto 0) := "11111111111000000000000000000000";
signal sbaud_tick_clk: std_logic_vector(31 downto 0);
signal strame: std_logic_vector(10 downto 0) := "11011010100";
signal rdata: std_logic_vector(7 downto 0) := "00000000";
signal cpt,sparity_value: integer := 0;
signal sparity : std_logic_vector(1 downto 0) := "00";
begin
    sbaud_tick_clk <= std_logic_vector(to_unsigned(868,32));
    sRX<=strame(cpt);
    c1: baudclk port map(clk => sclk, rst => '0',baudrate_clk_ticks => sbaud_tick_clk, baudclk => clkbaudrate);
    c2: UART_RX port map(clk =>clkbaudrate, rst => '0', RX => sRX, parity => sparity, timeout_value =>stimeout_value, error_parity =>serror_RX,timeout => stimeout,RXREG =>rdata);
    stimulis:process
    begin
        sclk <= '0';
        wait for 10ns;
        sclk <= '1';
        wait for 10ns;
    end process;
    baudrate_clk:process(clkbaudrate)
    begin
        cpt <= cpt +1;
        if cpt >= 10 then
            cpt <= 0;
        end if;
    end process;
    simulis_parity:process
    begin
        sparity_value <= sparity_value +1;
        sparity <= std_logic_vector(to_unsigned(sparity_value,2));
        wait for 400us;
    end process;
end Behavioral;
Could you help me to solve my problem please ?
Thanks in advance
joancab
Aren't you missing a clock here?
    begin
        cpt <= cpt +1;
        if cpt >= 10 then
            cpt <= 0;
        end if;
    end process;
Are you trusting the process to be done at every change in clkbaudrate for being in the sensitivity list?
joancab
    begin
        cpt <= cpt +1;
        if cpt >= 10 then
            cpt <= 0;
        end if;
    end process;
Norian
Thanks for your help.
You were right, the process was started unexpectedly because of clkbaudrate.
I am trying to simulate UART communication with a baudrate of 115200 so I modified the testbench like this:
-- Company:
-- Engineer:
-- Design Name:
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
library IEEE;
--library UNISIM;
--  Port ( );
end tb_UART_RX;
component UART_RX
        error_parity,timeout,end_reception: out std_logic;
end component;
component baudclk
end component;
signal sRX,clkbaudrate,serror_RX,stimeout,sclk,send_reception: std_logic := '0';
signal sparity_value: integer := 0;
signal cpt: integer := 0;
begin
    sRX<=strame(cpt);
    c2: UART_RX port map(clk =>clkbaudrate, rst => '0', RX => sRX, parity => sparity, timeout_value =>stimeout_value, error_parity =>serror_RX,end_reception => send_reception, timeout => stimeout,RXREG =>rdata);
    stimulis:process
    begin
        sclk <= '0';
        wait for 10ns;
        sclk <= '1';
        wait for 10ns;
    end process;
    begin
        wait for 8.7us;
        cpt <= cpt +1;
        if cpt >= 10 then
            cpt <= 0;
        end if;
    end process;
    begin
        wait for 400us;
    end process;
end Behavioral;
In this way the counter works correctly.
Again thanks for your help
joancab
Nevertheless, if you ever want that thing synthesizable you´ll need to implement a proper process with a clock, not a simulational delay.
I avoid non-synthesizable HDL as much as possible. It's fine for a very initial sort of 'proof of concept' but, imo, as there is an important gap between simulation and reality, I don't spend much time on that imaginary World. But it's just my approach, others may differ and have a point.
drjohnsmith
re simulation @joancab
its the only way to see whats happening inside your design,
     we design in a 9 state logic language, but in the real chip is 1 or 0,
        simulation is reality.
What I do agree on, is separating synthesisable code and none synthesisable code into different entities,
     Test benches almost by default have to be none synthesizable, as they tend to include clock generators,
        and lots of print statements  / conditional tests that can not be done in the FPGA.
joancab
@drjohnsmith testbenches, obviously are non-synthesizable. And needed. What I don't understand is why people write non-synthesizable functions that will never run in real silicon.
Norian
Of course I only use delays in my testbench. I completely simulate the sending of the frame in the testbench for my tests, my synthesizable components are the baudclk (clock for the UART_RX component) and UART_RX components.
richardhead
@drjohnsmith @joancab
I would usually follow the mantra of separating synth/tb code into separate entities. But it can be very useful to embed things like assertions in synthesisable code to kill a simulation when something illegal happens so its easy to trace back from point of failure. This often requires non-synthesisable functions (like using OSVVM Alerts). But you can easily put the --synthesis translate_off/on gates around it.
I also have packages with synthesisable code alongside what is clearly simulation stuff, purely because it makes life easier. Like having access types of synthesisable array types in the same package - again synthesis gated.
