Custom signal name
Hi all
On the waveform view you can select the signal name view between three values (long, short, custom)
How can i put a limit on the custom name length ? because i have large number of hierarchial levels !
Thanks in advance
Re: Custom signal name
You can "rename" the signal by double-clicking the object name and then entering a new name.
Then changing name to Custom will display the custom name given to the signal when renamed.
But i have a lot of components containing a lot of signal. Do i have to do this for each signal individualy ? This will be very exhausting. IS there a tcl command that can do this from the console ?
There's no direct Tcl command to "rename" the object.
You can only give a custom name with -name arg in "wave add" Tcl command.
e.g.
wave add /tb/UUT/data -name <custom_name>
Once you've finished, you can save the wave configuration file (.wcfg) and load it next time when you run simulation.
