DDR4 Read Sample Issue in VCS Simulation
I using the Ultrascale v1_1 DDR4 Controller and Phy in a VCS simulation with Denali DDR4-1600 Memory Models.
The sampling of the DQS lines in ddr4_phy_v1_1_xiphy_behav.sv misses the DQS pulses. This block uses a
delayed clock, o_clk_rd, to sample the DQS signals. I had to add an additional 100ps delay to this clock to
capture the DQS signals correctly.
Is there some external parameter that I should be adjusting rather than having to edit the verilog?
Re: DDR4 Read Sample Issue in VCS Simulation
@wtesling
Denali memory models are not officially supported by Xilinx, so please use Micron or vendor specific memory model for simulations.
If you still need MIG support with Denali models I would suggest you to contact your local FAE.
Hope this helps
-Vanitha
@wtesling
Hope this helps
-Vanitha
