01-18-2018 12:08 AM
Hi all,
I have a project in Vivado 2017.1. FPGA is Kintex Ultra-scale.
I created DDR4 IP in the project, opened example design and simulated. Simulation worked well and test passed successfully.
Then I created anothe project with ddr4_0_sim_netlist.v. ( I have also added the remaining files example_top.sv, ddr4_v2_2_axi_tg_top.sv, sim_tb_top.sv etc) .
But this time simulation did not work well. MIG do not perform any transaction (cs_n & reset_n to memory model are LOW).
What may be the issue?
Anoop
01-18-2018 01:37 AM
Hi @Anonymous
No, *_sim_netlist.v is post synthesis simulation netlist. To run the behavioral simulation you need to add the files listed in the simulation scripts located in .ip_user_files\sim_scripts\<ip_name>\xsim
01-18-2018 12:51 AM
Hi @Anonymous
ddr4_0_sim_netlist.v is structural netlist file. We support only behavioral simulation with MIG.
You can look at the example design simulation scripts (use export_simulation command) to know the list of IP files used for simulation.
01-18-2018 01:02 AM
Hi vemulad
Thank for your reply.
I am doing behavioral simulation of MIG only( with example_top and sim_tb_top).
As my understanding, for all Xilinx IPs which use .xci in project , *_sim_netlist.v can be used in behavioral simulation mimicking the IP. Please correct me if I am wrong.
Anoop
01-18-2018 01:37 AM
Hi @Anonymous
01-18-2018 02:00 AM
Hi vemulad,
Thanks. It clarifies.
So in order to perform behavioral simulation of MIG, I need to use either ddr4_0.xci or the .sv files generated from it. Am I correct?
Anoop
01-18-2018 02:02 AM
Hi @Anonymous
If you use .XCI file, the tool will automatically read all the files needed for simulation.
You have to include the memory model file separately for MIG.
09-16-2019 04:03 AM
I have one query related to this topic. Is there any way to simulate with ddr4*_sim_netlist?
