Anonymous
Not applicable
Data type error
I am having problems with a test bench file. I am getting the following errors-
# ** Error: C:/Documents and Settings/hitheshn/Desktop/Second_actel/stimulus/my_timer1_tbench.vhd(179): Signal "mmin" is type std.standard.integer; expecting type ieee.std_logic_1164.std_logic_vector.
# ** Error: C:/Documents and Settings/hitheshn/Desktop/Second_actel/stimulus/my_timer1_tbench.vhd(180): Signal "ssec" is type std.standard.integer; expecting type ieee.std_logic_1164.std_logic_vector.
# ** Error: C:/Documents and Settings/hitheshn/Desktop/Second_actel/stimulus/my_timer1_tbench.vhd(183): VHDL Compiler exiting
# ** Error: C:/Actel/Libero_v8.5/Model/win32acoem/vcom failed.
The vhd file was generated from a waveform. Not sure how to solve this error.
Any help would be great!
Re: Data type error
Check your signal types and assignments.  It appears signals "mmin" and "ssec" have been declared as std_logic_vector, and not integer.  Meaning, you cannot assign integers to these signals, but only a vector of bits (i.e. "00010010").
Eddie
