jobattle
Delay a Clock Signal without Violating Constraints
The snippet below is an attempt to delay the square wave ph1 by three clocks of hsclock.  It appears to work in my iVerilog simulator and it builds in ise but when I program it into a coolrunner part, ph2 just remains a zero level.
Notes:
    ph1 and ph2 are one bit rigisters
    delay_ctr is a n eight bit counter
    hsclock is approximately eight times as fast as ph1 and not coherent with it
    always @(ph1)
    begin
        delay_ctr <= 0 ;
    end
    always @(hsclk)
    begin
        delay_ctr <= delay_ctr + 1 ;
        if(delay_ctr == 3)
        begin
            ph2 <= ph1 ;
        end
    end
I believe I have violated a Verilog restriction of changing the counter register in two different always loops but, as I said, it works in the simulator and it builds with ise without errors.
Can anyone suggest a  way to accomplish the required delay function without violating the rule of not controlling a register in two different always loops?
John Battle
jobattle@caltech.edu
athandr
Are you checking in behavioral simulation or post fit simulation.?
Check post fit simulation for correct results.
Give timing constrainnts in your design and check.
Anirudh
gszakacs
Instructor
Instructor
You might want to check the post-fit equations in the report.  I'm pretty sure that if you really wanted to use both edges of hsclk, you need to do that by writing:
always @ (posedge hsclk or negedge hsclk)
By the way this only works in CR2, not other Xilinx families, and only because of the clock doubling feature of CR2.
My guess is that synthesis has just ignored the sensitivity list and tried to build something combinatorial.
Anyway, I'd suggest using a delay line (shift register) rather than the counter approach.  For a delay of 3 it works out to the same number of flip-flops.
And in any case you don't want to assign the same signal in two always blocks.  I'm not sure why synthesis did not flag this as a "multi-source" error.
-- Gabor
athandr
As you rightly pointed out, you need to give an intial statement for initializing the dealy_ctr. Also for the 2nd always block give a edge triggered loigc (posedge, negedge). Also instead of using an increment logic, you can delay it using 3 registers.
Try these options and check if it works now.
Anirudh
