Delayline Timing Simulation
I try to simulate the delayline make up by a carry4 primitive.  I built and implemented a simple one but simulation show that all the taps turn on at the same time (effectively no delay) when a step is applied at the signal input.  I would appreciate for any idea to fix the simulation.
Block Diagram:
Post Implementation Simulation:
I have attached the project if some one what run it.
Henry
Re: Delayline Timing Simulation
Hi @hyleung,
Please attach delayline.v and delayline_tb.v here.
Arpan
Arpan
HI @hyleung
Are you sure  it is a post implementation timing simulation?
Also, when you attach any project . Go to File --> Archive Project and send the created archive.(.zip file)
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
From the snapshot this won't looklike post-impl timing simulation.
As Bharath suggested check once again.
Also include 100ns of delay before start the stimulus. 100ns is required to satisfy the GSR (Global Set Reset).
Yash
I beleive you are running a Timing Simulation. Made the same project as yours and ran Timing Simulation (Post-Implementaion) and can see the timing working properly:
I have attached my project archive for your reference. Vivado 2015.2.
Debraj
The source file is included in:
\delayline_test.xpr\delayline_test\delayline_test.srcs\sources_1\new
\delayline_test.xpr\delayline_test\delayline_test.srcs\sim_1\new and
\delayline_test.xpr\delayline_test\delayline_test.srcs\constrs_1\new
I re-attached these files here anyway.
Hi Debraj,
Thanks for your project.  Unfortunately, I can't open your project because I am constrainted to Vivado 2014.2.  I have import your code but does not see any delay in post-imp simulation.  I am wondering if you can port your project into 2014.2?
Henry
Yes, I am pretty sure it is post-imp timing simulation.
Thanks for your reply.  I have try adding 100ns delay but doesn't make any different.
Hi @hyleung,
I tried with your code only.
It's working at my end with post implementation timing simulation.
The only concern I have it I think you have not zoomed the signal view properly.
Please try the following steps and let us know the outcomes:
  • Implement design
  • Run Post-implementation timing simulation
  • Keep the cursor on rising edge of tap[1] signal and zoom it.
Attaching snapshot of testbench for your reference.
Arpan
Arpan
I have rebuilt the project in Vivado 2013.3 and delays appeared at the outputs.  It seems that it is related to the 2014.2.  Is there anybody notice post-imp timing simulation issue with this version?
Hi Arpan,
Which version of vivado you used in the simulation?  I have the delay simulated in 2013.3 but not 2014.2.
Henry
Hi @hyleung,
I used Vivado 2015.3.
Which device and package you are using?
Arpan
Arpan
It is an experimental design.  For now, I targeted it for the K7 on the KC705 board.
HI,
If possible, do consider upgrading to latest version of Vivado.
This will ensure better results as many bugs get fixed along the process.
Tushar
Hi @hyleung,
As your design is working with 2013.3 either use 2013.3 else I would suggest you to use VIvado latest version.
Arpan
Arpan
Thanks everyone for the time on this issue.  I think I will go with the lastest vivado.
Henry
