Design simulation error
 Hai,
      My desige consists of IP core(fixed to float) generated in VIVADO. While simulating this design in Model simulator i am getting following error,
** Error: D:/DBF_NSTL/IIR_simulation/IIR_Fiter_simulation_K7_modelsim/sub.vhd(56): Library floating_point_v7_0 not found.
** Error: D:/DBF_NSTL/IIR_simulation/IIR_Fiter_simulation_K7_modelsim/sub.vhd(57): (vcom-1136) Unknown identifier "floating_point_v7_0".
** Error: D:/DBF_NSTL/IIR_simulation/IIR_Fiter_simulation_K7_modelsim/sub.vhd(59): VHDL Compiler exiting
how to over come this.
  In old version of IP, the Xilinx have used Library XilinxCoreLib;
theertha
Re: Design simulation error
Questasim is an advanced version of Modelsim with added Verification and Code Coverage features but the GUI and commands are same. You would not find any difference in the cockpit for both the tools . Feel free to use any one of them.
Debraj
To resolve this issue, recompile the libraries using compxlib. Check the following thread http://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-and-ISE-simulation-libraries-compatible/td-p/336003
Harry
There is no Xilinxcorelib in vivado.
Simulation models of Xilinx Vivado IP cores are delivered as an output product when the IP is generated.
Deepika.
Deepika.
In Vivado, the files IP delivered ususally bond to specific libraries.
I'd suggest that you launch Modelsim from Vivado so that the correct simulaiton script (.do) can be generated for you.
Use the following tcl command compile_simlib -help in the vivado tcl console for help on generating compiled libraries.
Thanks,Vijay
To add to what Grace mentioned, you can refer to chapter-7 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug900-vivado-logic-simulation.pdf for details on simulation with modelsim.
Deepika.
Deepika.
Hai,
   i launched Modelsim from Vivado. still i am getting error message
# ** Error: d:/DBF_NSTL/DBF_DESIGN_VIVADO/IIR_Filter_simulation/IIR_Simulation/IIR_Simulation.srcs/sources_1/ip/multiplier2/xbip_utils_v3_0/hdl/xbip_utils_v3_0_pkg.vhd(1): near "protect":
# ** Error: d:/DBF_NSTL/DBF_DESIGN_VIVADO/IIR_Filter_simulation/IIR_Simulation/IIR_Simulation.srcs/sources_1/ip/multiplier2/xbip_utils_v3_0/hdl/xbip_utils_v3_0_pkg.vhd(1): VHDL Compiler exiting
# ** Error: C:/Modeltech_6.3f/win32/vcom failed.
theertha
Are you using supported modelsim version (10.2a)?
Check the release notes page-11 for supported simulators http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug973-vivado-release-notes-install-license.pdf
Deepika.
Deepika.
Hai,
   I have gone through page no. 11. But in that model sim is not mentioned
theertha
Modelsim supported version is same as Questa supported version which is 10.2a for vivado 2013.4.
Deepika.
Deepika.
Hai,
    Now i am using ModelsSim SE PLUS 6.3f. So since i am using Vivado, I have tto use Questa  10.2a .Is questa will be same as model sim? (I have not used questa)
theertha
You can use Questasim 10.2a or above (or) Modelsim 10.2a or above.
Deepika.
Deepika.
Debraj
