Anonymous
Not applicable
Direct block ram instantiation, initialization file
Is it possible to initialize a RAMB16BWER in VHDL for both simulation and implementation using a file rather than the INIT(P)_xx attributes?
I've been using the RAMB16BWER primitive in a design, initialized via the INIT_xx and INITP_xx attributes. The initial values are generated via a script, so it's annoying to have to update the .vhd file every time I make a change there. The language template indicates there's an INIT_FILE attribute but I can't seem to find any information about the format of this file. I've tried giving it a MIF and a MEM file, both of which it will accept (versus a COE which it won't), but when I simulate it the memory is empty.
Cheers,
Jw
Historian
Historian
@Anonymous wrote:
Cheers,
Jw
Look in the XST User Guide for "Specifying RAM Initial Contents in an External Data File."
